    Thank you for your support!
:dung:.. changing the bulbs on gauges..help
1984 CJ7
Portland
1984 CJ-7, 258 (rebuilt), 5 speed (rebuilt), softtop, Goodyear DuraTrac's
So, of course, I broke the cradle thing that the bulbs are in on the gauge for oil and temp. Where can you get replacements? I went to Morris 4x4 and they are not on there. junk yard?? I guess you do not need to twist the socket off but rather pull straight out correct?
Ok, I will check that out! For some reason, mine didn't look like the kind you twist off a quarter turn. I will take a pic tonight and get your opinion
yes, I think you are correct but i thought they were twist. dang. I need a way to fix it now.
Here is the pic of the socket that is broken
How many do you need? I may be able to help you out.
2.. so far :) Thanks!!!
I have a bunch of them from the wiring I replaced so when you get done let me know how many you need and I will hook you up.
Thanks guys!
looks like i will only need two! Thanks again for your help!! I can pay for the shipping, Paypal.
Send me a PM with your info and i will get them out to you.
Perfect, thanks!! I will PM you now!
They are in the mail you should see them by the end of the week. And I sent you a extra one just in case.
You are the man!!!! Thanks sooo much!!
