Electric Fan Wiring assistance needed.
BrockGrimes
Jeep-CJ.com Archive Master
Kathleen, GA
ON THE HUNT AGAIN
looks good..I would probably put the light on the other side of the manual override switch..where it is now the light would be on even if the switch was turned off
I read the diagram as only having 1 fan with 2 relays wired in parrallel in case one of them went out and the other large circle being a toggle switch to manually turn it off when desired..if that is correct then it will work..You could add a thermostat controlled switch if desired..I would add it in series with the toggle switch and then parrallel another toggle switch with the thermal switch in case you wanted/needed to bypass it..
Pete I thought you were going to use the Toyota two fan set up. the Concourse?
This is the best information on Bosh relays I have seen. You can do a lot of cool things with Bosh relays. I am tempted by the "flash headlights left and right". I am sure that would be all sorts of fun.
http://dlcparts.com/images/BoschGuide.pdf
I picked up a 80ish amp constant duty solenoid for my contour fan. I wired it with 10 gauge wire. I run the ground for the relay to a 185 degree on coolant switch. The ground wire goes from the switch to my manual shut off switch (mounted upside down in my dash so switch down is on) then out to my relay ground. By doing it this way the motor is allowed to heat up to operating temp. Once it hits the 185 the switch ground out the relay allowing it to close and turn the fan on. If I need to shut the fan off to play in the water I flip my manual over ride switch to the up position and and it breaks the ground turning the fan off.
And like stated earlier your light is wired wrong. it should be wired to one side of the switch or the other. if you want to wire to the side that has power to it thats fine but dont ground it. power should go into the light then out to the switch. I would wire it on the ground side. Ground in then on terminal then out to the ground source.
I believe that the 2 relays is just a safety feature in case one fails..I don't use 2 on mine but there is no harm in it.
Doing it that way, if the bulb burned out it would stop the operation of the fan. Also the entire amperage load would then be pushed through the light as well.
exactly..the indicator light should not be wired in series with the circuit..it should be wired in parallel, after the switch,with it's own ground
No there is no harm in it but I believe it is best to apply KISS when doing DIY wiring. The liklihood the relay will burn out is low if you use a quality relay rated for 30 AMPS or more. You don't want the relay to be the weak point in the system that is what fuses or fusable link is for.
please tell us where a temperature activated variable speed motor controller can be found.:D
I dont know about a variable speed motor, but I linked the controller in my last post. If achieves differenct fan speeds by limiting the amount of amps the motor(s) are pulling starts at about 60% at the low temperature and up to 100% if the temp continues to rise. I rarely see it run longer than a a minute even in heavy traffic on my 5.4
Hmmm .. Guess I got a new task ahead of me.. Little bit of rewiring for some bulbs. Thanks for the correction
