Electric fuel pump for 304 v8
radman
South Dakota
79 CJ5, 304, T150, Dana 20, Corp 20, Superior one piece axles
2012 JK Rubicon 2 door
new project! what's the thought on an electric fuel pump on my 79 CJ5
with a AMC 304 v8?
will shortly move to south dakota where it'll probably be stored for winter.
seems that emptying the carb will be important and could be easily done
with an on/off switch.
ideas???
thanks in advance... radman
what about the fuel stored in the tank? if you plan on using fuel stablizer in there, you might as well run the engine until the stabilizer hits the carb to keep the seals from drying out while its stored.
great idea... any ideas on best brand of electric pump??
what about fuel pressure issues as well... since jeeps drink
gasoline by the barrel, do i need to get a higher volume
pump (or what)
radman
pump (or what)
radman
Most carbs should run in the 5.5- 7.5 PSI range.
