engine mount location
ramona ca
i have a 66 CJ5 with a 225. and my engine seems to sit off to the passanger side. like my fan is kinda on the lower right hand side of raidator. is this right should it sit off to one side. i only aske cause some one installed a signaw box and cut a hole through one mount to run steering rod. im woundering if maybe they moved the whole thing over to make room. also the hole for my snubber mount on crossmember doesnt line up. so maybe its the wrong crossmember maybe they moved the drivetrain to one side or maybe i got a bend frame just trying to find out thanx.
