Engine revving wide open
zig
- Central Michigan
- 1976 cj-7, 304, 400 trans with quadra-trac 4x4, Full fiberglass body
My wife drove the jeep home from work and it ran just fine. Then about 10 minutes later i went out to move it and started it up and it was like the throttle was stuck wide open. I turned it off real quick then tried again and it backfired really bad. So I let if cool down for a couple of hours and tried starting it again and it ran wide open again. I checked the pedal and throttle linkage and everything seems to be alright. Is there any thing else i didn't check that might be the problem.
