Engine RPM Calculator
Peanut Butter
Full Time Jeeper
Boerne, Texas
1979 Jeep CJ7 TH400 Automatic 258 I6 Quadratrac Amc 20 rear & Dana 30 front, 32 x 11.5 x 15 tires. Currently a Complete Custom Rebuild in progress.
Also I own a 2001 Jeep Cherokee, White, all stock with 4.0L. automatic, and police package. Best part of that is it came with leather seats! This package also has the NP242 Transfer Case, 8.25 rear end, and trailer towing package.
Want to input your tire size and gear ratio to get the rpms your engine will run at different speeds? Go over to Muscle Car at Power Block TV and click on the calculator on the upper right. Nice tool. Need some Transmission gear info, just scroll down the page with the calculator! Rod
Cool. Thanks for sharing.
Here's a chart I made. You want to shoot for the green. It shows engine RPM at 60 MPH
And derf made this much more informative gearing calculator: Gear Ratio Calculator
Or ((336 x road speed x axle ratio) / (tire diameter in inches - 1)) x Transmission gear ratio = rpms
