Engine Exhaust Pipe - Does this need an exhaust flange gasket?
Scottyp1134
Santa Rosa
86 CJ7 Laredo, 258, D300, AMC20, D30
Solution
I pulled the exhaust off replaced the studs and got new brass nuts that are a little taller. This allowed me to get a short socket on there since the deep socket wouldn’t fit with the curve of the exhaust. It seems to have closed the gap no problem and I don’t have any leaks that I can tell. I don’t know how the gap got there in the first place though. That part still remains a mystery.
Just tightens to the manifold
I have an 86 CJ7 as well and have encountered the same problem. Did you hook it up and go without the gasket? Did it work or is there still an exhaust leak?
Solution
Thanks, I also replaced tile studs and used new brass nuts. Hopefully this is how it’s supposed to be.
You have new brass nuts! Must be difficult to walk. I would be very pleasd to shake your hand!!
Time for a good polishing.
