First post - Tranny question
mudman979
Hey Guys! Good to be part of a knowledgeable forum. I been reading around a bunch, but this is my inaugural post.
I have an 84' CJ7 with a AMC 304 , T-150 /Dana 20 , and 2.73 gears. I'm sure most of you out there know where this is going.... She is pretty sluggish off the start and low range leaves a little to be desired. I don't want to change my axle gearing because I do like being able to take it down the road/highway, which is where I'll be 80-90% of the time. I do go off road, but I'm not really a rock crawler. I just want to make it a little more user-friendly; right now, starting on hills requires major clutch feathering and a third leg.
The PO put the T-150 /Dana 20 in it after the T-5 bit the dust, and he did include everything that I would need to swap a T-5 back in, even a Dana 300 and a short throw shifter. My conundrum is this, I know that the T-5 is known to be weak and the T-150 is a very capable tranny. I really don't want to downgrade my components, but I do need to change something. The T-18 seems to be the choice of, well.... everyone, but they are also expensive and hard to find. I know there are a lot of options if you have the cash, but I am hoping for an economical solution.
What do you guys think? Is there another tranny that could use the parts that I already have and give me the starting gear that I need, or would I just be better off by changing my axle ratio?
I appreciate the help!
