flexplate and spacer?
alaskaviper
Watertown, NY
83 CJ-7, 6 cyl. with Howell TBI kit, TF 727 transmission Dana 300 twin stick, 2.5" suspension, 1" body lift, currently under repairs,
99 TJ, 6 cyl., 4" suspension lift on 33s
I have a AMC 258 i6 / 4.2l and a TF727. I just got my engine back from the shop and need to attach the flexplate. I didn't take it off so I wasn't able to see where this other piece goes.
Does it go between the flexplate and the engine?
Also they gave me a rubber o-ring that came with the rebuild kit and said it goes on the crack between the flexplate and where it mounts. Is this right?
Ok I got the metal ring figured out, it bolts to the outside of the flexplate. I'm just not sure on the rubber o-ring. I can't seem to find anything about that.
