fluid t-150 Dana20
You know I can't remember, if I remember right they don't, however it doesn't matter as they use the same fluid.
If you find one low on fluid and another high. Check for leaks, also check the bolts that actually go into the case/fluid area.
The ones that bolt the two together.
