Front Fender Bolt Size
WV 77Cj7
Hedgesville W.V.
1977 Jeep CJ-7 Renegade
Ran a search but no luck. Im in the process of body repair and need to know the size of the bolts that attach the fenders to the front of the tub. Ive got a couple of the weld on nuts that have rusted and need replaced, so I need to determine their size.
Thanks!
3/8" -16 x 1 1/2" Body Bolt = tapered end w/washer
Thanks!
If you are talking about those 3 bolts each on the body side to the fender those are 5/16"-18, and suggest fender washers. Some guys do use a gasket between the two also.
Yep.......... all the front fender bolts I've seen are 5/16"
:D:D:D:D
Sorry guys, don`t know why I was thinking 3/8", maybe because I was working with 3/8" for days.
Brakes Disc
$70.00
  35.0%
