fuel and speedo gauge
rogiestone
Atl GA
83 jeep cj7
it is time to install gauges in the 83 CJ7 off frame v8 build i would like to install a nice set of autometer gauges but would like to retain use of the speedo cable coming from the T-5 if not there is always a hall effect sending unit. I would also like to use my stock fuel level sending unit. dose any one have suggestions on which gauges to use? ( ohms for fuel gauge ) ( speedo gauge to accept cable)
Jeep uses a 73-10 ohm sending unit, the same as Ford. On Autometer's web site, they show a speedo with cable in-put. It gives dimensions for cable. You will have to see if yours will fit.
$35.00
  17.5%
