Gear Ratios compared!
rocmoc
Tucson, AZ & Mexico (both Mainland & Baja)
1970 CJ5, V6, 3spd, power steering, headers, electric fans, upgraded larger radiator, '78 grill, disc brakes (front only), swing pedals, hyd clutch, extended front shock mounts, upgraded front driveline w larger u-joints, warn OD, D30 front diff, lockers, 2100 carb, working on a '74 tub replacement, '78 windshield frame with '78+ Acme hardtop
Anybody have the ratios of the auto 350 compared to a 14? Looking at a conversion in a CJ5 so looking the 350 because of the shorter length when compared to the 400.
Thanks,
rocmoc n AZ/Mexico
Got them, sorry for the bother!
T-14 : 3:10, 1:61, 1:00 rev, 3:10
Turbo 350: 2:52, 1:52, 1:00
SO, this generates a different question.
How much effect in crawling over the tough stuff does the difference of the two low gears have? V6, 35" tires, 4:88 gears, will it still perform at an acceptable level with the higher gear in the 350?
rocmoc n AZ/Mexico
Low range is your friend.
thats about %30 give or take. thats quite a difference.:D
rocmoc n AZ/Mexico
:)rocmoc,
Due to the torque applied through a "Good" Converter the low gear ratio near double's itself in low gear only.........So think 5:1 in Low gear.
:D:D:D:D
