Grill assembly support/mount
Wrangled13
Indianapolis
1979 CJ5, 304, completely rebuilding it.
Looking for a place to buy the grill mount/support (bolt, washer, bushing) from the bottom of the front of the frame to the grill.
'79 CJ5
Thanks!:chug:
Pretty sure it's not available or even included with a new body mount kit. It's been discussed numerous times on jeepforum.com and I believe some guys ended up making their own by welding a washer to a bushing.
I think that may be it. I dont think it comes in the body bushing kits. Mine is SHOT so need to come up with something.
Mine came with my poly bushing body mount kit. I did not get the bolt or washer though, just the poly bushings.
4wd hardware sells a stick of rubber body mount bushing material that you can cut to your desired length. It is pretty cheep and then you can make your own. I am pretty sure it is a Rugged Ridge product.
Thanks Kane. I'll look into it. Placing an order on 4x4 today yet so illsee if they have it
Sent from my probably outdated electronic device, more than likely tracked by our government.
Thanks Duke, that guy's prices are kinda out of control if you ask me.... I think I could make one for cheaper, but thanks anyway!
So I will be creating my own. Got a hockey puck that is just dying to be used on this jeep. This will get interesting
The puck will be in. If the vet give me the right pressure hose
there's a guy on ebay currently selling the bushing setup.
I believe the rubber body mount kits will start including these later this year, too.
  5.0%
