Hei
81laredo
- Idyllwild, CA
- 1981 CJ7 Laredo as built, 1952 Pontiac Sedan Delivery, 1955 Thunderbird, 1958 Airstream, 1996 Tahoe 4X4, 1982 Newell Coach, 1957 Cabin in the Woods what will I work on next?
I have been reading about the HEI distributors and decided on the CRT. CRT states that they use the proper gear and it will not produce problems with the cam gear, don't know if I should trust them.
It has been discussed that you should use your old gear and move it to the new distibutor. The shafts are not the same size though, AMC = .535" and the new CRT = .485".
1st) those of you with the CRT...how long has it been in and any problems?
2nd) did those who did the gear change use a bushing and is it worth it?
thanks in advance
thanks in advance
