Help a noob pls
Rotor Wash
- Hawaii
- 1982 CJ 7
I-6 with warner T4 tranny dana 300 x case ( all stock from my understanding)
Hello everyone,
Thanks for the warm welcome to the forum. Since I got my jeep I have been busy fixing all the things a 28 year old jeep comes with .
So yesterday I was replacing my worn belts and noticed that i have a hose coming off my front axle and going no where.
Where do i need to hook it in too ?
Along with my belts yesterday I replaced my missing PCV to carb vacuum line. It did have one when i got the jeep. After I reconnected the line, white smoke/vapor started coming out of the aft breather and from around the PCV grommet and the idle is a little ruffer now . When i unplug the line NO smoke/vapor, plug it in smoke/vapor .
Have I found a new problem and what do i need to do to fix it ?
Is this my EGR and what vaccum line needs to go into it ?
So what canister vacuum lines am I missing ?
Is there a way to test my temp & fuel gauges without pulling the instrutment cluster apart ?
They both dont work and me and wire dont really work will together.
In the interest of cleaning off some of the miles and age built up over the years. I wanna Seafoam the Fuel tank & system, engine oil and carb. So just that I dont make my life any harder. I wanted to run what I was going to do with the seafoam before the masses before I blow my motor apart.
One can into the fuel tank to clean from the tank to the carb injectors.
1/2 can into oil crankcase.
1/2 can poured into the carb as it's idling or should I pour it into the PCV line that goes into the valve cover.
Is that right ????
Thanks for the help and understanding.
_________________
It happens !
Is that right ????
_________________
It happens !
