Help-Emergency Flashers Not Working.
Canadian CJ 7
British Columbia
Current Setup 1985 Jeep CJ-258, 6cyl -T-5 5spd 273 gears.
Hi Guys, when I am stumped I come to my friends here on this board for help. My problem is with the emergency flashers, They worked up till yesterday, with both the engine on and off. I replaced both the turn signal and emergency flasher relays at the top of the fuse block as well as checked and tested the emergency flasher fuse and it was good, I even put in another fuse just to make sure and fuse was good and my light tester indicated it had power. All my lights, turn signals and brake lights all work, the hazard lights are the only thing that doesn't work any ideas or suggestions appreciated.
Thanks, Brian
The next thing to be looked at would be the switch. It could be worn out or damaged/shorted out from dirt.
