    Thank you for your support!
help identify frame bracket
ksouthw80
georgia
1978 CJ7.304, t150,D20 w/teralow- twin stick, dana 30/AMC20. 35 sst's on procomp wheels.
what was this bracket used for? The one almost under the oil filter. just guessing it looks to line up with the flat pad of the Dana 30 (bumpstop?)
It's a 'bump-stop' for the axle. Should have a rubber snubber on it.
