help need finish height
bgolden
Mooresville, NC
79 CJ 7 304 all stock except 4 " lift 33" tires Golden Eagle
I need to know if anyone has the finish stock roll bar height of a 79 CJ7 with a 4" Procomp lift with 33" tires on a 8" rim I am restoring and forgot to take a measurement before begining I want to know if It will fit in the garage I have the jeep down to the frame so I cant just put the body back on yet I would like 35" tires but just need to make sure it clears the door.
You will be fine until you put the top on. Then it requires a roll up type garage door.
Thanks I did some measuing and it looks like it will clear by a 1.25" with the 33" tires simply cant take the chance on 35"
