HELP! Wiring complications
76cj7chick
Old Time Jeeper
- Solutions
- 1
- WA
- 1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Hi everyone!
I've been banging my head against the wall for sometime trying to install a 21 circuit wiring harness in my 76 CJ7 from EZ wiring... I've emailed them and didn't get a response and I just left a vm earlier today.. But instead of waiting on them I thought I'd turn to you all for help...
The PO(s) did a scary job on the jeep... It had a lot of bare HOT wires, hanging ground and many other issues.. (I hope to get a video together and put the build on youtube or?
I purchased a complete wiring harness hoping it would either have all the connectors (since my jeep lacked many) or had good wiring diagrams... Unfortunately, it didn't come with either....
The diagram has two headlight switches but neither are for my jeep. It also didn't tell me where to install the Orange Brake light Switch power (I think I figured it goes on the brake pedal switch?) But not sure yet...
If any one knows the wiring PLEASE let me know!
I still need to wire:
Brake Switch (white)
Backup light power
Left backup light
Left front park (brown)
Left tail park (brown)
fan wire
fan fan wire
PS. I have 3 jeep manuals, one of which is a technical manual but they are still quite vague about where wires go...But mostly perhaps because the POs have done so much wrong and since I am installing an aftermarket harness... But I would appreciate any ideas from the masters...
I have the brake combination valve on the frame of the jeep.. I figured out where to wire the one that goes to the parking brake to the dash warning light but am not sure where the other one is to be wired... The diagram looks like it is supposed to be spliced into the ignition somehow... Any ideas?
I have many other questions but won't throw them all at you right now...
Thank you again in advance....
Backup light power
Left backup light
fan wire
fan fan wire
