Help with troubleshooting my grinding problem..
Rexx66
I've been pretty lucky with not having any major issues with my CJ5 since I picked it up early last summer. Well the time has come I think for some major cash flow (in my mind at least)
I noticed about a week or so ago when shifting from 2nd to 3rd gear (only a 3 speed BTW) that it would OCCASIONALLY grind briefly. So my friend and I jokingly said I should start double clutching', not granny shifting' (F&F reference). And I noticed that when "double clutching'" from 2 to 3, it wouldn't grind.. but I knew the issue was still there.
Then on this past friday the gears were being a real PITA and would make weird noises while in 1st or 2nd, still grinding when going from 2 to 3. And sometimes now it is a little tricky to get into 1st when taking off.
I have no clue where to start or where to look for issues. I've never done any Transmission work, but have a feeling I'm going to be learning soon. I have a competent friend who is UTI trained, ect. ect... but this being an old vehicle we are both a little lost on where to begin.
Is there somewhere I can check fluid if that would MAYBE be an issue? I've been told by my father in law that I can adjust the clutch and that may be it too..?
Any help would be greatly appreciated.. I don't have the time to work on it myself for too long so it will probably get taken to a local classic car shop here in town and let them deal with it, unless it's something I feel I can do with my friend in the garage..
Thanks for any help I can get!
