Hood Compatability
Hood Compatability
dagr8tim
Columbus
75 CJ5, 232, T14, Dana 20, Dana 30, Dana 44
97 XJ, 4.0, AW4, 231J, Dana 30, C8.25
I'm 99% sure I know the answer to this question, but here goes...
Will a 68 CJ5 hood bolt up and work on a 75 CJ5 ? I got a smoking deal ($20) for the hood and it's in far better shape than mine. The only issue is that somebody plugged the tiedown bracket holes. I looked at it quickly and it looks like a sheet metal screw. I'm hoping it's not welded, and just bondoed & painted over.
68 is Kaiser era 75 is AMC. AMC stretched the engine compartment by adding to the hood and fenders. I believe the 68 hood will be about 4" shorter.
Sent from my DROID RAZR using Tapatalk 2
Bowbender has it right. Actually the AMC hoods are 3 inches longer.
Check out this link: http://www.jeep-cj.com/forums/f102/cj-spotters-guide-11933/
[FONT=FreeSans, Arial Unicode MS, sans-serif] CJ5[/FONT]
[/FONT]
1955jeepwillys' 1955 CJ5​
[FONT=FreeSans, Arial Unicode MS, sans-serif]The CJ5 was produced from 1954 to 1983. It no longer had the flat fender look of the earlier models. The CJ5 was originally intended to replace the CJ3B but that model continued to be produced until 1968. The feature that distinguishes the CJ5 from the CJ7 is the shape of the door. [/FONT]
[FONT=FreeSans, Arial Unicode MS, sans-serif]American Motors bought the Jeep company in 1971 and in the following year AMC engines were used in Jeep CJs. The engine compartment was lengthened to accommodate the AMC engines. How can you tell if a CJ5 has the longer hood? Notice how the curve of the front fender in the above picture goes to the seam of the body. Compare this to the AMC CJ5 below. Here the curve of the fender ends 3 inches from that seam.
[/FONT]
[/FONT]
Well.... Maybe I'll paint it with chalkboard paint and hang it in the garage.
$75.00
  37.5%
