Wiring How does the blower motor get ground on a cj7. 1980. I have 12 volt on the wires. Switch works, no blower
eberg833
europe
Kaiser cj-5 , buick 225 V6 odd fire /T14 1969. Dana 44/27
CJ-7 1979 AMC 258, T18 AMC20/Dana30
How does the blower motor get ground on a CJ7 . 1980. I have 12 volt on the wires. Switch works, no blower. Tried a by pas from battery. No Lucky so far.
Solution
How does the blower motor get ground on a cj7. 1980. I have 12 volt on the wires. Switch works, no blower. Tried a by pas from battery. No Lucky so far.
When I reinstalled mine, I put a self-tapping screw into the blower motor mounting flange and ran a wire from that over to one of the heater mounting studs at the firewall.
To securely ground the firewall I used two of the heater mounting studs that ran through firewall, cleaned the firewall down to metal on the engine side of the firewall, installed a stainless star washer, a stainless coupling nut, then a lock washer and bolt on the other end of the coupling nut. Ran a heavy gauge wire from the bolt on the end of the coupling nut to the negative terminal on the battery...
To ensure a good ground it is best to run a ground wire to the stud.
X2. I’ve had my CJ for 40 years. Not a rusty CJ either. Never had a ground problem until 6 weeks ago.
This gives an excellent ground to the firewall directly from the battery for everything using the firewall as a ground, but also gives a good ground connection for anything else in the engine bay.
If you are into the heater, you might think about upgrading the motor to a Chevy blazer motor for a very good increase in air flow.
I did a write up on the process here.
Lower Heater Restoration Link
Fresh Air Box Restoration Link
Hope this helps,
Mike
Solution
Hope this helps,
Mike
Thank you. Problem solved.
