I dont get it
DIG
ok so I put a new water pump from quadratec on the jeep and now the pully is rubbing with the crank pully.......any thoughts on why this would happen?
What part number did you get from QT?
I know the pulleys are very close together, are you positive that the pulley is seated all the way against the flange?
Two different scenarios, he never stated that the pulley was contacting the pump...Can't seat against the flange because the PULLEY IS HITTING THE PUMP!
As in hitting the pump before seating...
