I made a deal
I made a deal
rr41mag
Full Time Jeeper
Panama city florida
04 dodge truck, 1966 chevy truck, 2012 rav4
And finally a 1981 jeep cj7 258 hardtop
It's an 80's scout front and rear end, the rear end has been gone thorugh with a posi installed. Comments??
A Scout front end isn't worth the powder to blow it to Hell. The rear end is fairly good.
Neither is a bolt in deal.
Why is the scout front end not so desirable?
Because they come from the factory with 0* caster.
You have to cut the C's off and reweld them on to have the correct caster.
That's one way.
Others are:
shims on the spring mounts​
adjusting shackles (within reason)​
You need to look at the entire system.
I passed on Scout axles because the tube wall thickness is not as heavy as some.
It doesn't take much to put 5x5-1/2 rotors on a Dana 44 Cherokee/ Wagoneer 6x5-1/2 wheel bolt pattern. Does the Scout axle have discs? Sooner or later you'll want to upgrade. :D
from what my friend tells me all the brakes are brand new.
