installing winch
installing winch
Dan86CJ7
Mass
1986 cj7 258(rebuilt motor/comp cam/weber32/36) T5 300 tcase d30 front(locker/4:10s)
AMC20(locker/4:10s),4"lift,33"s
so i had no plans for one but my dad shows up w/ a winch for me to put on my cj. so i got a warn mount coming but need few answers.
Is there anything i need to do/upgrade to run the winch? is it gonna require dual battery or will one work? Any advise would be awesome.
You could hold off on the extra battery if you don't feel you need it, I use just one Optima battery, which seems to be good for emergencies. When you do use it, it is always good to keep your eye on the voltmeter so you don't empty the battery. They do need to have both electrical cables hooked up directly to the battery, and there are emergency switches on the market for if a relay sticks that are attached to the positive cable. It is a good idea if you don't run the winch much to run about 20 feet or so out to keep the seals lubricated every month or two. That should get you started.
thanks bud, just dont wanna burn anything up trying to use it and dont have to much experience with them.
One battery is fine for self-recovery but if you are gonna be dragging other people's jeeps I'd suggest you invest in a 2 batt. setup sooner rather than later.
Don't hook the winch to side posts. Get top mount lugs and attach winch cables to those, and hook your starter to the side posts (if your battery has side posts).
Unless you're doing a LOT of winching one batt will be fine. I've had my winch for about 10 years, probably only used it about 20 times, and haven't ever had any issues from my battery.
Oh I realise that. My negative cable from the winch is attached to the end of my negative battery cable. Same path just easier to attach to.
Two batteries is best but not needed.. I have a bunch of heavy gauge welding cable that was taken off a waggoneer with a triple battery and winch set up If your interested I can send you some of it if you want to pay for the shipping.. It looks like 00 wire all you would need to do is have ends put on it. shoot me a PM if interested.
I had a 9000 lbs winch on my Cherokee with one battery. Used it a lot in the mountains of Colorado. Even pulled rocks out of my yard with it. Never had a problem, always left the engine run and under heavy load at high idel.
One thing though, onky saw this onxe but once will rain on your day, leave the winch in free spool mode ehen not in use. Sinxe it is direct connect to battery, any short in it that causes the motor to turn will pull enough juice to start a fire under the hood. If free wheeled, the motor will run till battery dies, but no heat or fire. Only saw this once, but it was enough for me. Rod
Thats a great idea about leaving it in free spool. I like the 2 battery idea with one designated as the winch battery so you dont kill your main starter battery.
thanks for all the replies. now i gotta wait for the mountin g plate to come in.
thanks for the tip, will deff. be getting those....$10 for piece of mind...well worth it:)
:)What really works best is to have your Hot lead run through a HD continuous duty solenoid or relay that is triggered by a switch on the dash or in my case I used a separate keyed switched.........that does not allow power to the winch unless I'm ready........ keeps the kids or others from playing with buttons.
:D:D:D:D:
Well I had never heard the "no winch on side posts" before! Guess I now have another thing to add to the list of "while I'm at it... :D
Thanks wm69
~ Jr
Side posts have a ribbon connection to the top posts and some battery makes.
I have seen side post failure during hard winching.
I would not risk it.
I use top post terminals with wing nuts. When I am not using my winch, I disconnect the lead. Cheap and is positively disconnected.
I also know a guy who's winch cable came out while he was driving down the road. He ran his winch in free spool and he had simply driven threw tall grass before hitting the highway. He flipped his jeep.
I will not drive with my winch in free spool mode.
Good Luck
Watch those disconnects...many aren't rated for the continuous current some winches draw.
