Misc Is the AMC 20 Single-Piece Axle Upgrade Still the "Preferred" Method?
iChuck12
Southeast PA
'78 CJ-7, 258, TH400, BW 1305 QuadraTrac, AMC 20 Rear, D25 Front Diff(?)
'76 CJ-7 "Levi's Edition", (Still figuring out the specs under all of the rust)
Do yourself a favor and get a set of one piece axle shafts. Mine were so bad my machine shop had to use their 100ton press. It finally popped after cutting a slit and taking it over 30 tons of pressure. Sounded like a gun shot when it finally let loose
Thanks for the advice. I've started doing my homework to make sure I find the correct set for the QuadraTrac . 30 tons of pressure; that's insane!
If you opt to keep the AMC20 with the Moser or other quality 1-piece shafts, make sure you get some top notch bearings to go with it. I installed 1-piece shafts with bearings from the local parts store and had bearing failure on one side after a few 1,000 miles. Ruined the new shaft as well. Ditched the Dana 20 and now have a Dana 489 rear end and love it.
Yup, as far as I know, one-piece shafts are still a preferred method if you want to keep the Dana 20 .
Our boneyard has a few discarded D20s. Heck, I'd give you one if you'd like :), but I don't think any are the offset QuadraTrac type.
Yup, as far as I know, one-piece shafts are still a preferred method if you want to keep the D20.
Our boneyard has a few discarded D20s. Heck, I'd give you one if you'd like :), but I don't think any are the offset quadratrac type.
Thanks for the offer KRUPP. I think I'm going to go with new one-piece axles on both sides with some quality bearings (Thanks TSB8C). However, a jeep boneyard sounds like a place I'd like to vacation!
$70.00
  35.0%
