jeep tailgate question
jeremy5780
South west FL
1985 cj7
My CJ7 tail gate drops down to an angle when i put the tailgate down. It is not like my truck tailgate that sits level so you can sit on it. I ordered a new set of tailgate cable's but they are just as long as the ones on there. Is this normal from the factory?
Thats interesting, Torx....It's been quite some time since I've had the tailgate down on mine, but I seem to remember that mine drops down below level, too. I just figured that's how it was.
My '84 sits level.
I cant remember any of mine not being level. :confused: 79 , 80 , 81, 82, 83, and '85.
are your cables mounted in the correct locations
just ran into that issue while reassembling my jeep . This is gonna sound strange but the hinges can be installed upside down. Witch results in the cables being too long ,and the gate hangs low or angles down. If you look at the hinge the pivot point is not in the middle of the hinge. hope that helps.
Reactions: GRR
What bigwrench said. The first set of hinges i ever installed I put on upside down. The long side of the hinge goes up. Short side down.
Reactions: GRR
