Jeep with 304 has surging issues Help please.
mahler81280
Hey everyone this is my first post on the forums! I have an issue that started randomly a couple of weeks ago and I have done everything I can think of to fix it.
I have a 1980 Jeep CJ7 with a AMC 304 V8 and I it started this weird surging one day. I will be sitting there at idle and it will surge from 1600 to 1900 RPM's randomly about evbery two seconds. It's got a Holley 4160 carb. Here is what I've done to try and fix the issue but non of this has solved it.
Took apart the carburetor, cleaned everything so it practically looks brand new.
changed the spark plugs
checked for vacuum leaks
changed the rotor on the distributor
changed the fuel filter
adjusted the idle screw and the air to fuel mixture ratio
So far nothing has worked on trying to fix this problem. Any help would be greatly appreciated.
Here is a Youtube video of the tachometer so you can see what I'm talking about.
Jeep idle surging - YouTube
