Just picked up a new CJ5
bbinion1
Atlanta, Georgia
Hey everyone, I'm new to the forums here. I just picked up a new CJ5 74' Jeep and I was wondering what motor came in this. I'm not sure if the guy before swapped the motor or not. Pictures are below. Thanks.
Welcome bbinion1 to the site. Lot's of great people here with lot's of knowledge to pass along. You have a AMC V-8, most likely a AMC 304 cid they came in the CJ5 as an engine option. You can tell a AMC V-8 by the way the distributor is in the front on an angle like you have. Your engine stamp AMC 304 should be on the side of your engine block also. Hope this helps.
Brian
Just to add on to this that is an Amc motor and whatever number is embossed on the side of the block will be the engine size. AMC 304 , 360, 401. :)
Welcome bbinion1 to the site. Lot's of great people here with lot's of knowledge to pass along. You have a AMC V-8, most likely a 304 cid they came in the CJ-5 as an engine option. You can tell a AMC V-8 by the way the distributor is in the front on an angle like you have. Your engine stamp 304 should be on the side of your engine block also. Hope this helps.
Brian
Its pretty big about 2 inches high Id estimate. You should see it no problem. Been awhile since I had the V-8 and I cant remember wich side or if it was both. It should be easy to spot though.
Ive got the ps pump and brackets for a AMC 304 if you are interested.
Trans 81 CJ8
