little stripe going around stock spoke wheels.?
GoldenEagle36
SW Pennsylvania
1977 cj7 Golden Eagle 304,automatic, Quadra-trac, full restoration just "finished." 4 inch superlift, lift shackles in the front, sitting on some KM2 Mud terrians
1999 tj 4 cylinder ax5 trans 3 inches lift 31s
1956 Dj3a all original except axles and engine, Hurricane 4 cyl. 4x4 conversion, 27,500 original miles 58 Jeep-A-Trench cj5 8000 miles.
You may try a local car show. Te ones that I have been to locally usually have a pin stripper and they could do this for you. These guys usually drag a wooden box of materials around the show looking for work.
Not sure but I would expect that you would simply raise that wheel and let the stripper (or you) spin the wheel so that he could get the job done.
good luck.:driving:
i have seen the material for pinstriping rims at some motorcycle shops.. it usually runs $10- $15 for a roll of the material and the tool so you have the perfect line.. works really well and has a strong hold.. used it on my old street bike. so if you can find any motorsports stores around you i would suggest checking there.
I am currently in the process of restoring my 1978 CJ5 Golden Eagle and I just finished sand blasting the rims today.
I ordered the wheel paint from Paintscratch.com (Corsican Poly Gold) and was just going to use a black paint pen for the pin striping so I can protect all of it with a layer of clear coat.
If you do it yourself you can save yourself a lot of money and wait time....only problem is it takes a lot of patiences to make a straight line (or circle in this case) but its well worth it.
$35.00
  17.5%
