locker instal- shaft/pin removal question
rbagley
Kalamazoo, MI
82 CJ7 w/258 I6 (Weber 38/38) de-smogged
5 speed manual BorgWarner trans
Dana 300 transfer case
Dana 30 front. AMC 20 w/lunchbox locker
Yes sir, that roll pin holds the cross shaft in place.
And I cant remember if that pin hole goes all the way through the carrier or not...If so, just drive it all the way through.
If not, a nice little trick to these is to carefully rotate a small wood screw into it and tap it out using the screw head.
Yep, it does go all the way through you should even be able to push through pretty easy, even with something as simple as a screwdriver and hammer.
I am not sure what is on the other side...if this pin would have made it through or not- I couldn't believe how long it was. I was determined to pull it out rather than push it through just because I was scared that I wouldn't get it back if it didn't work as planned.
The first screw was too small, it pulled right out. The second one ended up snapping off at the head, but still was able to get it out by prying against the Vicegrips that were clamped on the threads. I love Vicegrips- probably one of my favorite tools. I have about 12 pairs in different sizes :D
Figured I would post a few pictures for the next guy.
I had a snow day today (6" in MI combined with ice over night) so tomorrow (Sat) will be free to put the new locker in. My progress on the whole Jeep is being documented on the build forum. 82CJ7 frame & lift build
Thanks guys for the advice! I am pretty excited to make some progress. I did this today while I was waiting for the welds to cool down on the new leaf spring perches I replaced today.
Ah, I didn't pay much mind but saw you left the carrier in. It might not have been as easy to push through. It just comes out the other side but cjim was right on.
I still find vicegrips quite helpful myself on occasion :).
CJ007 - Can I take the carrier out without any technical skills? Do I just need to take the 4 bolts out (which will allow me to take the caps off the bearings)? ...as long as I keep track of the bolts, caps and bearings- making sure I put them back in the same spots and tighten them to specs when I am done.
Is there anything else I need to make sure of? Do I have anything to worry about with the ring gear or anything?
I didn't know if I could just take it out or if it would have to be professionally lined back up. I have Limited knowledge with these (as you can see).
Thanks for your input.
Rick
Yes, you can pull the carrier. As you stated, mark the caps so they go back the way they were removed, this includes the side and orientation. It can be a little difficult to py out and put back in as the pumpkin compresses the bearings for preload, but a few pry bars can get it out and a dead blow will help you put it back.
I use a prybar to remove the carrier. Like CJ said, keep correct orientation of the caps and bolts. This is a great time to inspect the bearings, be careful re-installing so as not to chip the ring and pinion teeth.
    Best for votes
    on specific items
$100.00
  50.0%
