Locker problem / u-bolt conversion
Lightnin 1
- Hobbsville NC
- '84 CJ 7, 4Cyl., Dana 300 T/C, 3.54's w/Lockrite & 1 piece axles, pretty much stock.(FOR RIGHT NOW!!!!)
That's not neccesarily true....I simply drilled the threading out of the yokes and installed the U-bolts.To change from straps to U-bolts, you will need new yolks.
I've never had a powertrax but I would think it would engage as soon as power was applied like all the other lockers. Sounds like something is not moving right inside.I got a powertrax locker in an AMC 20. It does not lock in until I'm spinning, then when it locks, it does not want to disengage. Also, what is involved with swapping out the U-bolt straps for regular U-bolts. Been told by quite a few people to make this switch......![]()
I find that interesting, CJim7, since the hole centers are different between the later model CJ straps and the older style CJ u-bolts.
Get new yokes to change to the u-bolts.
Got the new seal in today.....
Still got a leak.
Crocus cloth was used on the yoke to help with the grooves cut in it by the seal. Still got a leak. Have I overlooked something or is gonna be time for a new yoke????
