Looking for fresh air vent cable not dash one
huntingbigun
Dover, FL
1982 CJ7 258 Hard Top T5 Dana 300,
2011 F250 diesel 4X4 ,
2011 Diamondback Airboat with 800 Hsp LS7 Supercharged Mast Motor
Pulled the heater out of my 82 CJ7 and replaced core cleaned out the leaves and replaced couple cables, lubed all the doors but my secondary cable that opens the vent is really stiff been lubing it with tri flow so anyone know where to find it. the part number out the manual is
J546 2343 item 15 of figure 24-200, runs from the bellcrank to airbox passenger side thanks
Gotcha, secondary temperature control cable. If you can't salvage yours you could try JW wrecking.
Quadratec sells all of them. I bought a whole set before.
I just replaced vent wire with piano wire!
A gear head at work told me that if you need a stiff thin wire, that quite often piano wire would work. So I took my cable in to the local piano guy and he said it was a large piano wire and he had the same size in stock for 35 cents a foot, he chuckled when I told him what it was for and told me that the bulk of his wire sales are not for piano's but for other projects.
Interior Dash Pad
