Misc. Looking for Pics of Stock Front and Rear Suspension 1980 CJ7
PJD
North Chesterfield, VA 23237, USA
1980 CJ7 258, Manual, Dana20
Just purchased a 1980 CJ7 that was lifted I am told
The previous owner stated they removed lift but I believe not all the parts are back to stock
Does anyone have stock suspension pics
Also Should sway bar rotate in mounts when picked up by frame my linkage is hitting tie rods when picked up
A common problem when the sway bar hits the tie rod is if you have some amount of lift (spring, shackle, etc) and still have the stock length sway bar connects. Longer sway bar connects are needed when adding over a certain amount of suspension lift (2" or more). You can tell if there's any lift by some easy measurements.
Stock CJ height from ground to rocker panel is 18". Stock tire size was 29". If running larger tires than stock, measure from ground to rocker and subtract that 18" amount plus half the difference your tire size is over stock. i.e. running 33" tires means you are 4" over the stock 29" size. So measure the distance from the ground to the rocker, subtract the initial 18" and then subtract 2" more for the oversize tires. The remainder is the overall combined lift from suspension, shackles, body (or whatever combination you have).
I am running a 4" suspension lift with 35" tires. I'm sitting at 25" total distance from the ground to the bottom of the rockers. So the math is 25" total height, minus the 18 stock height it started at, minus 3" for tires (my tires are 6" over stock height), leaving 4" of lift. Since I know I have no body lift and stock length shackles (3" bolt to bolt), I know I have 4" lifted springs.
TSB8C
Thank you for information.
I believe there are lifted suspension parts still on her.
We will put in new drag link tie rod and ends and put tires back on and take some measurements tomorrow
A new straight pitman arm should be here tomorrow the existing has about a 3" drop.
I believe from my Chiltons book that the springs are not stock
The front has 5 leaf's not seven and the rear also has 5 leaf's not 4 as in pics in manual
Also stock shocks from Napa are two Short
Shocks too short and a drop pitman arm are certainly quite suspicious.
We had to drop the front spring shackles to get the Tie Rod and drag links out.
When we get the new ones in tomorrow we will start measuring
the shackle bolt gauge is 3" c-c where can I find info on correct spring data for stock? she does have a 2" body lift which we will subtract out for tomorrow once we get her back on her wheels
Thanx
