More power for the Iron Duke???
Draugr
Hallsville Tx
1980 cj7
Have my first Jeep with the Iron Duke dont want to put in a a bigger engine But im looking to find ways to squeeze everything out of her
Electric fuel pump
Electric fan
sure fire plugs???
and anyone give some advice?? thank you:D
This is the same engine found in a Fiero car, some thought it was a sports car. You might find performance accessories in a search on the car.
hedgehog is correct...in 1983-1/2 the 84 the Pontiac, Fiero was introduced and there were many performance parts available from the general. I think most of the the stuff was for all out racing but I would think you should be able to find a cam, header and intake. good luck.
The iron duke is really a pretty good little engine...if you freshen one up they have good durability and longevity. Be sure to replace the cam gear as they wear pretty quickly and will cause a knocking noise like a main or rod bearing type noise. Many many good engines have been scraped because of the cam gear knocking sound.
the last owner stated he just did a compression test and it was at 125 per cyl how big of a cam can i get with out a rod / spring change?? any advice??? I though about going out and getting a electric fan and fuel pump and maybe high milage oil or royal purple oil???
My advice would be to try a different axle gear/tire combo, like a bit lower on the gears and a little larger on the tires, I believe you have 4.10s now. I have wheeled with guys with the 4 bangars and they seem to do just fine. Especially looking at that little engine after doing a great 4wd trail. The major complaint is little power on the road as they pass the gas stations.
I agree with torx- they are good little engines...and the right set of gears would really help. If I were you...I'd just freshen it up with good a exhaust system and tune...
here's a link for some camshttp://www.compcams.com/catalog/COMP2012/pdf/COMP_Catalog_2012_240-247.pdf
but you need to really think it out. If I remember correctly the duke has a non adjustable valve train which can be a pain when changing the lift. So be sure to talk to cam expert. I also don't know for sure if the engine you have is exactly what Pontiac used in the Fiero. good luck
Have my first Jeep with the Iron Duke dont want to put in a a bigger engine But im looking to find ways to squeeze everything out of her... ...anyone give some advice?? thank you:D
What year CJ and what Transmission ? Your profile just shows the 75 with the I6.
The 151 (2.5L) inline 4 engine was used in '80-'83 CJs including the CJ-8, CJ-7, and CJ-5. The 151 is often called the "Iron Duke", but is actually a Pontiac engine designed to replace the Chevy "Iron Duke" I4 engine. The engine does have the Chevy bell housing bolt pattern though. The engine is manufactured by GM and uses a cast iron block and cylinder head with hydraulic lifters and 5 main bearings. The 151 cetainly is not a screamer, the AMC I4 has much better HP and torque ratings.
Daily Driver Performance??
Run stock size tires, 235R75/15 with either a highway tread or an all terrain tread.
Get the engine tuned properly. Ideally, that would be getting it dyno'd so you have a baseline, and can see what your A/F ratios are doing across the RPM band.
Keep the weight down. A CJ has all the aerodynamic qualities of a brick. Experiment and find you 'sweet spot' as far as speed goes for MPG.
Off Road Performance??
Gearing. Plain and simple. Most GM 151 engines had either the SR4 , T-4 , or T-5 Transmission . All light duty gear boxes. IMHO, if you are going to even think about a bigger tire, you need to address the axle gearing first. The stock 30/20 combo is 'generally' good for up to 35" tires, with some minor upgrades (1-pc rear axles). But if I was thinking about slapping a set of 33-35's on it, I'd also be considering an engine/Transmission upgrade.
Screaming Street Performance???
Full race treatment. But the Transmission will probably grenade. The GM 151 is used in a number of racing categories. I think I even saw one with a Cosworth head on it. Your checkbook is your limiting factor
it is a GM 151 and do run stock tires on it the guy i got it from was a mechanic and new-battery, exhaust, spark plugs, fuel filters, and fender flares. It has a remanufactured carb on it. did a compression test on the motor and it has 125psi per cylinder
