Motorcraft 2100 post swap questions
elwood blues
Always Off-Roading Jeeper
- Export, PA
- 1978 CJ7 4.2L Comp Cam & valve train, MC2100 carb, MSD ignition, Dana 30 front, T18 trans, Dana 20 txfr, AMC 20 rear.
I finally got my carb swap done and the CJ running again. But I have a few lingering questions. The Motorcraft carb replaced a single barrel Carter YF. The Carter only had a mechanical choke. The Motorcraft has an electric/mechanical choke, other than converting to a manual choke, does anyone know how to utilize the Motorcraft choke?
I still have an exhuast leak, it's a decent ticking that no matter what I tighten, I still have that exhaust tick. I was thinking of taking the exhaust manifold back off and applying a liberal amount of Permatex Ultra Copper. Does anyone know if that will work? Thanks.
Thurston
Thurston
