MSD distributor cam gear roll pin question
mopar440cu
- Sumterville,Florida
- !979 CJ5 Silver Anniversary model with AMC 360/340HP, T18a, Twin stick Dana 20, AMC 20, D30 (both rebuilt w/ 4:56 gears) Moser rear axles with trac loc and 36 TSL Swampers.
I have a 1979 CJ5 with a AMC 304 . I am working on replacing my distributor cam gear on my 1 year Napa with a MSD cam gear but, the hole where the roll pin goes does not align with the new MSD gear.
The only way it will align is I have to take out the shim, which I do not know if I can do this. I took a micrometer to both MSD and the stock Napa one that came off and the MSD is a slight different. Forgive me I forgot the measurement but, will go back and get it again if need be. My question is can I take off the shim without hurting anything? I have been searching for the answer but, I can not find it.
I would appreciate the help!
but, what a pita it was drilling the MSD hole needed on the opposite side. Thank God I have a drill press and could clamp it down to drill.
