Misc Need help identifying bracket
70Shark
Minneapolis
78 CJ7, 304 T150, D20, D30, AMC20
Solution
That bracket goes on the back of the power steering pump and is where you adjust the belt tension. The square hole goes facing up and is where you would use a ratchet to push and hold tension. The two round holes are for the bolts you tighten to lock it in place. The "knub" sits in the hole on the larger bracket and serves as the pivot point. Here's a pic of the rear of the pump and how/where your smaller bracket fits in place between the pump and the larger bracket, and another pic showing the placement from the front without the pump in the way. The entire set of brackets is available on eBay as well in case you're missing the other parts: eBay Listing
Throttle bracket ? Part missing.
Well then as my dad used to say, It’s one of those mysterious things in life.
Solution
Wow. Thanks everyone! I already have the power steering mocked up on the engine and thought it was complete. Probably would not have worked well without it. I was even thinking this was left over from my 'vette restoration finished years ago. Now I can fall asleep without thinking about it. Thanks again.
Well, I'm glad that is figured out and also pretty mad that I missed that. The size was the decieving issue. I need a vacation!
$70.00
  35.0%
