Need help to identify my oil sending unit
danray48
- NE Ohio
- 79 Jeep CJ7, 258 T150, Dana 20 soon to be T176, Dana 300
While wiring my centech harness, I wired my oil pressure gauge according to the wiring directions, and that part is ok. My existing oil sending unit has a place on it for a oil line, but it was solderd shut. The sending unit is a one wire slide on connector, (my gauge does not have a place for a oil line) I wanted a new sending unit, so I ordered one from Morris, for a 79 AMC 258 i6 / 4.2l motor. The one I got is a three prong unit. My wiring harness came with one wire marked "oil". My question is, Is the three prong unit for a mechanical gauge, or the one wire unit? I should clarify, that the old sending unit is screwed in and not part of the brass fitting that has the solderd oil line. Am I making sense? The main question, is does a mechanical oil pressure unit have a 3 prong or a 1 prong connection. I just thought the 3 prong would be for reading resistence. My wiring diagram does not specify which one......Thanks
