Need help w/ transmission/transfer case mount
cdlongjr
Newark, De
1983 Jeep CJ-5, 1987 Wrangler YJ, 1974 J-10
I'm still trying to get the Transfer Case installed. I was changing out the mount & found the exsisting mount is 2 rubber top hats & a stud. The new mount looks like a bell. Can anyone tell me which style is the correct one for my 1983 CJ5 ?
Above is the one I removed.
This is the one I was sent new.If this one is correct, which parts are between the skid plate & the channel where the rectangular mount that goes under the Transmission ?
CD, as far as I know, all CJ's from 76 - 86 us the same mounts.
This is what I come up with. -->> Transmission Mount*1370910
And the stabilizer for the Transfer Case is the same to. -->> Transmission Mounting Stabilizer Stud*5358879
The bushings. -->> http://www.jeep4x4center.com/product-information.asp?number=945266
There are many, many different variations of these so even though it may look slightly different - it could still work.
Thanks CJ!
I looked @ Morris, but didn't see these.
