Body Need help with body mounts
jimonfly
Lawtey, FL
'78 CJ5
I'm trying to remove the 2" body lift from the previous owner. Both of the front rocker mounts had bolts broken off in them. I was a able to get both out fairly easily but I can't get new bolts back in. The bolt will just start to thread then binds. It doesn't go into the capture nut. I can threat is into the capture nut from the top, but then it binds when it goes into the body. I removed a middle mount bolt to make sure it was the same size and it is. The broken pieces are also the same size/thread as the new bolts. Now I can't get the middle bolt back in. It goes into the body and binds. I don't think it's getting to the capture nut.
Is the body threaded before the capture not? I wouldn't think so but I can't figure it out. I don't want to force the bolt and risk snapping another.
Solution
No, the body is through until the nut. Sounds like the body has slightly shifted. I would loosen all the body mounts to allow it to free until you get all the bolts started.
Solution
I didn't get to try. It was Mother's Day weekend and we're trying to get out of town. It will have to sit for a couple of weeks before I get back to it.
Have to take care of Mom!
I had the same problem. Check for proper body alignment like admin. said
$20.00
  10.0%
