New Clutch not working??
I just installed a new clutch in my CJ5 that has the AMC 258 i6 / 4.2l liter with the T-14 3 speed Transmission . I made sure it was all aligned using a old transmission shaft and everything seemed to go together well. Since it was out I also replaced all the linckage from the clutch pedel to the clutch fork. Once I got it all back together I tried adjusting the linckage to give the pedal the proper amount of play and make sure things would run smoothly but I cannot get it to engage. The thing won't shift into any gear. When I try all I get is grinding. I have adjusted to the extreams both out, in and everywhere in between but nothing.
I am going to take the tranny off tomorow to check what I may have done wrong. Any suggestions on what to look for (is there a common item that is forgotten or overlooked by first timers?) since my skill level is Limited at best.
Thanks again, this site always come through...
