No fuel
No fuel
54cj3b
COLORADO
1954 willys cj3b
1976 dj 5 rhd
1981 dj 5 rhd
1988 xj
1993 xj rhd
2006 kj
1976 dj AMC 258 i6 / 4.2l same as a CJ5 only RH drive
1.) Replaced carb
2.) Replaced filter
3.) Replaced fuel pump
4.) full tank
Ok this is what I get Pump is working fuel flows through filter and out end of fuel line when not connected then I connect line to carb and nothing all vacuum lines are connected to proper ports ect runs great if I pour fuel down carb throat but Im not in to running along side pouring gas in carb while going down the roadbiggrin.gifbeer.gif
Ideas
Help
thanks
__________________
Any chance you have a stone filter at the carb inlet? If you do, take it out.
No its an exterior screen filter that attatches to the end of fuel line and screws into the carb
heres a idea what im talking about
not an artist so drawing dont count :rolleyes:
You might look behind that threaded fuel fitting and see if a brass screen or stone filter is attached to it.Float stuck shut in the carb.
Mike
As said, IF, you have a carb with a stone filter, it will be located behind the fitting, but not all carbs have them. Not too many things can cause the fuel to quit running through your carb, and one of the things could be a frozen float, but it could also be that some debris got into a pasage and blocked it. Try tapping on the float bowl and see if it wont free the float. You may need to pull the carb and go through it.
Im thinking the floats stuck now from all the input im getting from all the sites I posted on
thanks everyone for your help engs are my specialty carbs not so much
john
found the problem was a old crudy screen jammed up in the fuel port
