Not Starting
Not Starting
Midwest
1985 CJ7
hey guys, its the novice wrencher again. i just put everything back together on my jeep. its turning over but wont start. all my wires are hooked up. why wouldnt i be getting any spark or fire?? its a chevy 350.
Hei ?
Are you getting fuel to the Carb? Is your timing set to 0° at tdc? Is there any after market modification made to your ignition or electrical systems? THERE are numerous tests you could be doing but before I can say where to start I need a little more information.
if you got power giong into the dist. but nothing comming out test the coil and ign. module. (if it's hei)
a little more info on the set-up would help.
