Oil in coolant...
Oil in coolant...
007
Crazy Sr. Respected Jeeper
Reno, NV
1977 CJ-7 Renegade (Daisy Jane), Levis trim, 304, TH400, BW1339 (MM), D30/Auburn Max, AMC20/Detroit/G2's, 4.88's, 33" BFG MT KM2's, Edelbrock Performer intake, Holley Sniper 4bbl EFI, MSD6, MSD ProBillet distributor, OME shocks, 4" ProComp lift.
Have a buddy question. He has a Jeep with a 4.0 in it. Has some oil in the coolant. Haven't see it first hand but is this likely a head gasket issue? There does not seem to be coolant in the oil, just oil in coolant.
I suppose it could perhaps be Transmission fluid in the coolant though as well though correct?
4.0s are known for having a lean tune from the factory which causes them to run a little hotter. I would suspect a cracked head as well. I see it all the time... Especially if they've run over temp a few times. If he goes to remove the head send it to a machine shop to get it cracked checked unless you can see it.
Good Luck!
Thank you. That's what I was leaning toward. Much appreciated.
I'd do a compression test.
Agreed. I will pass it on.
Thank you all!
Any way you look at it, this isn't going to end well. . . :drool:
Well it may not be oil. It's a light brown floaty. See below.
Any milky streaks in the engine oil?
Have you done any work on the cooling system of late?
Not my Jeep... But no milky streaks. No rainbows. No engine or cooling work of any kind.
How many miles on the engine?
What the jeeps history?
When was the last time the coolant was changed or tested?
Engine Oil
