Oil leak!!
Oil leak!!
Midwest
1985 CJ7
i started up my jeep and i have oil dumping out of it at like 2 quarts per minute. it seems to be towards the top of the block and at the rear of the block. i took off the air filter and carb to get a better look and i cant see where the leak is coming from. is there a common thing around this area of the motor that goes bad? it sat all winter and didnt have this problem before i parked it. i have no clue what it could be. the motor is a 350. im afraid the only way to find the leak is to pull the motor! help, thanks.
If your talking about a chevy 350 the oil sending unit is at the back and top of the center of engine. I'd check that.
