Hi all, my stock oil pressure gauge does not function. after spending enough time on this i am going to install a non-electric gauge for reall pressure readings. but, where should i install the fitting on the block? i'm new to this kind of work, i have 25 year old memories of auto shop to help me and lotts of books but i still can't find the answer or picture that helps.if this had a trigger and a barrel i would be set.
It depend on the year of CJ and its not to the "right" or in your bio info.
The 80 CJs have a pres transducer and a pres switch..
The 70 Cj's only have a pressure tranducer.
The electric switch is Normaly Open and closes with oil pressure. Oil Pres Switch will activate a relay to turn on Electric Choke Heater. It can also be used to turn off electric fuel pump in case of accident it would interrupt a circuite and shut down fuel flow. Users may come up with other devices they want to shunt down it no oil pressure.... even a oil pres alarm.
The Pressure Tranducers and Gauges are not interchangable.... There are deep gauges, thin gauges, and Full Size Gauges and they all have different transducers. I have posted the numbers for the correct transducer to work with the correct gauge...... Its up to you ... show me a pic of your gauge face and the depth of gauge (inch or pic) and I can tell you the right transducer to get...
If you look at my posts I have put it here on this forum 3-4 times already. If you would like to find them... Look at my signage and then will box with see posts/threads
I have posted the transducers OHM readings for no pressure and some pressure settings using a Gauge, regulator, multimeter. Measure the resting impediance of the transducer and that alone may tell you what transducer you have.
I am on the look for a 2" or deep version of the voltage... mine in is rough shape and have not come across a clean one.... Took my oil gauge apart and cleaned and calibrated it a bit...... looks like new. MY volts gauge looks so sun faded it must have spent a few summers outside with top off in prior life...
IF you want the gauge there are a few options. The block mtd is a 1/8" NPT so std brass fitting will work also. I also came up with a simple maifold using std brass parts and will put up pic.
JH also showed me a std grease gun WIP is 1/8" npt on both ends, used for oil service, and can handle high pressure. Use the WIP from block to a alumium manifold block you make... Mount gauge, switch , pres transducer right on the manifold. Can also connect your oil line if still wanted.
There is a good post around web on Trouble Shooting CJ Gauges.... by John Strenk... Search those words and it will show up...He did have a mix up on the gauges with what years and ranges when he copied over or made changes... I think it was updated... but use my transducers numbers if you move forward.
The sellers of the transducers list they cover CJ from early 70s to late 80s and it is not true.
Regards,
Fred
nice to see another gun guy
