Pinion oil seal replacement
I have a CJ7 with a Dana 30 front axle. The pinion seal is leaking and needs to be replaced. I have a manual but the job calls for a number of AMC tools that are not available now. What exactly do I need to hold the pinion yoke while taking the nut off, what to use to pull the yoke off, and what size of socket do I need to pull off and replace the pinion nut?
