por 15
por 15
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
When you use the por 15 system should you mix the marine clean with water or just use it from the spray bottle as is? how long do you let it sit before cleaning the marine clean off with water?
Did it come with any instructions or are any listed on the container?...you would think that they would send instructions with it?
The instructions came with it but were vage. Or at least to me they were, cartoons instead of precise info.
I looked at their web site under directions. It said mix 1:1 with water(hot) is best. Says it could take up to several hours to work. Rinse with water when done.
Did my frist por 15 worked all right. Lots of fumes had to keep the dogs out of the shop.
